跳转到主内容
The Xiaomi Redmi Note 3 smartphone was released by Xiaomi in March 2016. It includes a non-removable 4050 mAh battery and supports up to 256 GB of removable storage.
34 个问题 查看全部
Which charger wires should connect on the tip?
Hi I'm trying to fix my broken charger of Xiaomi Redmi 3s before a new one arrives. As you can see on the picture, there are four pins on the charger tip and four different colors of wires. Can anyone tell me which color of wire should go on which pin? Thank you.
Picture link :
https://imgur.com/a/SmqDk
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is the pin layout for USB ports
(click to enlarge for better viewing)
这个答案有帮助吗?
得分 1
2条评论:
Thank you very much, I will try and report back.
完成的
Working perfectly. Thanks.
完成的
添加一条评论
添加你的答案
Negiku 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 164
