跳转到主内容
Part Number: DD11210 The TotalPond pump, which was designed for water gardening enthusiasts, circulates 210 gallons of water per hour, maintaining the ecological balance of small ponds. It is used in water garden less than 3 feet by 6 feet ponds and waterfalls to provide streams of water up to 7.8 feet high.
2 个问题 查看全部
Need screw on flow regulator on throttling valve for TotalPond pump
I have a 800 gph TotalPond pump that is missing the small screw-on flow regulator that screws into the Throttling Valve. Where can I buy one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @mrditto ,
It might be easier and quicker to contact TotalPond direct and find out if the part is a) even available and b) where to get it from if it is.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ditto Bolinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 125
