跳转到主内容
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
211 个问题 查看全部
rare problem when inserting discs
hello folks, I have a problem, in my console when I insert a game only the laser turns on but the motor that makes the disc move does not rotate, what I did is to put the ribbon cable that goes under the motor to the other side and when putting a disc now if it rotates, but it changes speed so it never reads the game. I saw the ribbon cable and you see a separation in the contacts, as if it had broken, the problem is only the 9-pin ribbon cable and the rest is fine ?? sorry for my bad English, is that I do not speak English, thanks in advance!
EDIT: Here are some vídeo footage about my problem https://youtu.be/nP7hH0BO_bk
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try to get a new ribbon cable and replace the cable. u can probably find one online somewhere, shouldn’t be too expensive
这个答案有帮助吗?
得分 0
2条评论:
I'll do it as soon as I can, plus I forgot to say that the lidsensor ribbon cable was also broken so, to do the test I pulled the cable from the power button and inserted it into the lidsensor, thanks for answering since I started with the intrigue that the logic board had been damaged but I corroborated that theory since I have some demos on the HDD and if they work, I also thought that the disk engine was damaged, which would be strange since I rarely played on the ps3, and when I was going to start playing more often since I got the saints row 3 and that problem occurred, if the problem is solved, I'll give you the points !, if not, I will notice anything in case someone will have this problem
完成的
Hi dude, look at this, its my problem https://youtu.be/nP7hH0BO_bk
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 254
