跳转到主内容
加入维修社区 - 创建账户
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
Replacing iBook G3 14 800Mhz Logic Board
Have a iBook G3 14" 800Mhz that I need to replace the logic board. I have a replacement 800Mhz logic board, but it seems that on the new board, the contacts for the battery are right on the board, rather that a plug where you attach the connector to the battery terminals. These contacts for the battery do not seem to line up where the battery would be anyway. I have worked on a few of these machines but have never seen this before.
Has anyone seen this before and do I need some other part to install this board.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
I am not sure which board that I have. I cannot find those numbers anywhere on the logic board.
完成的
OK, it seems that the replacement logic board is the 661-1779.
完成的
添加一条评论
2个答案
已选择的解决方案
You received a 12" ibook G3 board. Return it and ask for a 14" one.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
There were two logic boards for the 14" 800 MHz G3
661-2678 (16 VRAM)
661-1779 (32 VRAM)
There were also two 800MHz logic boards for the 12" models. What do you have?
这个答案有帮助吗?
得分 2
3条评论:
It is the 661-1779
完成的
I examined the photos you emailed me and the boards just don't seem to be interchangeable. I would return the board and get the correct one.
完成的
Thank you, that seems to be it.
完成的
添加一条评论
添加你的答案
studio58 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 1,145
