跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Bootloop, Screen slightly messed up, and a little bent.
So, I have a friends iPhone 7 they gave up on (Actually it was their moms first). Despite all the problems it has it still looks pretty clean and it let me reset it. Looks like someone changed the screen, even the buttons still work... it is missing a screw for the battery cover.. would that cause the bootloop even after reset? Should I just Junk it? lol, Still fixable ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I certainly wouldn't junk an iPhone 7 without at least trying to fix it. A lot of things can cause boot loops and because this phone was previously repaired, there is probably a link between the two. You really should explain more about the bend and what exactly is "a little messed up". Perhaps a picture would be helpful.
Unless you have some modular issue, such as a weak battery or defective screen, this phone will most likely have to be looked at by an experienced micro-solderer.
这个答案有帮助吗?
得分 1
1条评论:
It's a slight dent into the right side in between the sim and power button. I can post pics tomorrow. The screen has lines through it and green on the side... if you can picture my description lol. Thanks for the feedback, as I said I'll post pics tomorrow. Hopefully it's not that bad I need a micro-solderer.
完成的
添加一条评论
添加你的答案
Shaolin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 166
