跳转到主内容
Motorola Moto 360 2nd Gen Smart Watch manufactured by Motorola Mobility in 2015. Wearable Smartwatch that connects to your phone.
My physical power button is stuck
Hi
Physical power button on my MOTO 360 2nd gen is stuck.
Can anyone help me out
- Sairam
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
What do you mean with "it's stuck"? Is it like pressed in? Or you can't press on it?
完成的
Can't press it on Alex
完成的
添加一条评论
4个答案
id start with a deoxidizer, and spray it into the power button, and try to work it in by pressing the button while it settles.
if that doesnt work, open the watch and verify that the button itself on the board is in tact.
if the button is fully in tact, then remove the button from its opening in the frame, and dremmel the hole a little bit bigger. (less than a milimeter is usually enough)
这个答案有帮助吗?
得分 0
添加一条评论
I've also had this problem.
I used a pair of needle nose pliers to rotate the button and break up any material that had solidified around the button. And cleaned it with isopropyl alcohol.
这个答案有帮助吗?
得分 0
添加一条评论
do you jave any method to fix this issue
power button stuck
这个答案有帮助吗?
得分 0
添加一条评论
Posted using AnySend MSG 647.9
You have to simply rub with isopropyl alcohol, after that charge the watch power button facing downside, the charger will heat up and help rescuing the power button, then stop charging but don't remove the watch from the dock, let it cool. Then turn the watch again on, I had the same problem. It fixed after doing this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sairam Karuturi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 4,456
