iPhone 7 which is dead
i have an iphone 7 which is dead i tried everything i could but nothing, i measured every single caps on the board but no short and ,also i did connect it to a power supply zero amps , but when tries to boot up it goes up to 0.06 or 0.07 ma and stays there
i was wondering if someone can help ,also i measured voltages from PMIC
all the rails have the right voltages :{
and i tried to make it hot with power supply but as the currents consuming is very low it doesn't produce enough heat
thanks for reading :)
did you check tristar
由 daniel 完成的
Or batt_main?
由 iMedic 完成的
Yes i did replaced the tristar and batt_main is work well as i get normall voltages from pmic
由 yousef 完成的
is it taking amps on the power supply without the power button being pressed
由 daniel 完成的
hi ,no it does't
由 yousef 完成的
显示更多的4条评论
