跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
3D Touch works bad
Hi all, a few months ago my iPhone screen broke and as there are no official Apple stores in my country had to repair it with no official services. Since the screen broke I went through several technicians and changed more than 5 times of screen and I still have the same problem. none of the screens is responsive as the original, sometimes when typing very fast the screen does not take the letters correctly. But the biggest problem is that the 3D Touch does not work as it should, there is no difference between the 3 levels of pressure and it only works when I use my thumb. It's as if it only works when I use the entire surface of my thumb. no matter how hard I press just to support my thumb with the largest surface of my finger the 3D Touch is activated. Has anyone else had this issue ? ifixit screens work in the same way as the originals?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi Elias, where are you purchasing the replacement screens from?
完成的
添加一条评论
1个答案
已选择的解决方案
That is a lot of displays to go through. To have the same issue. It likely is the displays. Yeah, I would say iFixit has good displays. They also have a really good warranty program. What country are you in? Could be better for you to purchase a display through the iFixit EU site
iPhone 7 Plus 屏幕更换
iPhone 7 Plus Screen
iPhone 7 Plus Screen图片
产品
$74.99
这个答案有帮助吗?
得分 2
2条评论:
Yeah, in this point I don’t know what to expect, my last hope is that ifixit screen work well. I’m from Argentina I think I can buy from USA page
完成的
@eliasnvr Hello! Could you please update us if you bought from iFixit and the 3D touch was working fine?
完成的
添加一条评论
添加你的答案
Elias Navarro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 927
