跳转到主内容
标准款Xbox 360的轻薄升级款,配有250GB硬盘和Wi-Fi功能。维修需要用到复杂且特殊的工具。
Does not read any disks
disks are used but all seem OK. Not that bad. I Always get the can't read disk clean disk or restart console error. I'm pretty sure this isn't this the disks and none of them will work. Is this a thing where you just to take it apart and go and clean the optical lens? Has that worked for others or are there other issue that may cause this? (While I'm in there I of course will clean everything else but at this point the tray opens and closes fine.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Did it read any disks before this problem started occuring?
完成的
Yes the machine is a few years old and worked perfectly. Then it just stopped reading all of the ~25 discs we have. I have since took it apart and cleaned it as per many varied instructions on you tube. I sort of worked. I did get it to read a few discs but it's still not great... still having some similar issue and often getting same error message of clean disc or restart console. any other suggestions?
完成的
添加一条评论
1个答案
已选择的解决方案
Probably want to replace the optical drive
Labor
Xbox 360 S Optical Drive Replacement
Parts
IFixit is apparently out of stock
Xbox 360 S Motherboard and Paired Optical Drive
Can't seem to find one on eBay or another seller. You can get the reader..but I'm pretty sure it needs to be paired...
Replace a broken or damaged motherboard and paired optical drive for your Xbox 360 S game console with this part. This part includes the bare motherboard with attached ports and the paired optical drive. Heat sinks are not included.图片
产品
$59.99
这个答案有帮助吗?
得分 1
1条评论:
if you replace,make sure it matches the drive.there were 2 or 3 of them.
完成的
添加一条评论
添加你的答案
Bryce Holbech 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 129
