跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
33 个问题 查看全部
pink stripes on dark background and green stripes on white background
i was playing a game when suddenly the screen turned pink. i got worried and closed down the game...and while doing so.. the screen went black as the application shut off....then there was pink color coming from all sides of the screen and stripes form and the screen from black turned pink..and on white background it shows green stripes
It has Intel(R) Pentium(R) CPU B960@2.20GHz processor
System type- is 64bit operating system x64 based processor
please help....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
Your problem could have a number of causes and we will need to work towards excluding the unlikely ones. First, update your post with the specs of your laptop.
Now. The problem could either be the GPU that went bad because of overheating or the display cable, that could also have gone bad due to overheating.
To see which components is not working as expected, connect the laptop to an external display. If you still see the stripes on the external monitor, then it's the GPU that needs to be replaced. If not, it might be the display cable.
这个答案有帮助吗?
得分 1
2条评论:
完成的
If it were to be overheated...what do I do?
完成的
添加一条评论
添加你的答案
Kizong Lama 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 75
