Why is there no power to the iron. No indicator light on.
Whilst ironing the power light went off and iron stop working.
Many of the UK heating devices have a fuse within the plug. Carefully open the plug to gain access to the fuse. Here's an image of the plug assembly from the Morphy Richards Iron Teardown:
While not stated you'll see the far left & right connectors are also the fuse clips. With an Ohm or continuity tester you should see these are connected (with a fuse in place), If not you need a new fuse.
这个答案有帮助吗?
1. check the cord
2. there is a fuse in the steam iron press, get it replaced by service centre.
4. Thermostat is not working.
4. heating rod is damage.
这个答案有帮助吗?
Where can I get my iron seen to ? Rescaled it now won’t come on just keeps going off checked fuse new fuse in but still not coming on !
过去 24 小时: 21
过去 7 天: 106
过去 30 天: 391
总计 26,958
3条评论
I have lefty iron forgot to turn off just noticed but the iron is off and now won't work
由 Susan Bracken 完成的
I’ve a steam iron generator it’s stopped workin the light doesn’t come on no heat nothing can u help?
由 tina.kavanagh@hotmail.co.uk 完成的
My iron won’t switch on .. change the fuse
由 roseann01 完成的
