跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Morphy Richards Iron,请使用我们的维修手册
  1. Morphy Richards Iron Teardown, Morphy Richards Iron Teardown: 步骤 1 中的图像 1,1
    • This is the iron we will take apart.
  2. Morphy Richards Iron Teardown: 步骤 2 中的图像 1,1
    • First remove the rear or the iron using the flathead screwdriver.
  3. Morphy Richards Iron Teardown: 步骤 3 中的图像 1,1
    • Next remove the cable bridge bracket.
  4. Morphy Richards Iron Teardown: 步骤 4 中的图像 1,1
    • Next remove the screws from the base. (see arrows for location)
  5. Morphy Richards Iron Teardown: 步骤 5 中的图像 1,1
    • Next remove the screw the hold the top on.
  6. Morphy Richards Iron Teardown: 步骤 6 中的图像 1,1
    • To free the long cable remove from terminal block at rear.
  7. Morphy Richards Iron Teardown: 步骤 7 中的图像 1,1
    • At the front of the iron pull out the buttons for the steam and water.
  8. Morphy Richards Iron Teardown: 步骤 8 中的图像 1,1
    • Next unclip the button holder (red circle) by undoing the screws (black circle)
  9. Morphy Richards Iron Teardown: 步骤 9 中的图像 1,1
    • Next remove the bridge clip from the arrows position.
  10. Morphy Richards Iron Teardown: 步骤 10 中的图像 1,1
    • Next remove the inner button (black circle)
    • Now remove the centre screw (red arrow)
  11. Morphy Richards Iron Teardown: 步骤 11 中的图像 1,1
    • slide off the cable holder from the cable.
  12. Morphy Richards Iron Teardown: 步骤 12 中的图像 1,1
    • Disassemble the plug
    • First remove the casing.
    • Now remove the wires from the pins.
    • Next remove the pins.
  13. Morphy Richards Iron Teardown: 步骤 13 中的图像 1,1
    • Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
  14. Morphy Richards Iron Teardown: 步骤 14 中的图像 1,1
    • Next take out round selector, this is simply clipped so can be pulled out with pliers.
  15. Morphy Richards Iron Teardown: 步骤 15 中的图像 1,1
    • Next remove the washer parts at the front of the iron.
    • Take the tubing off.
  16. Morphy Richards Iron Teardown: 步骤 16 中的图像 1,1
    • Remove the seals for the water pump.
    • Now take pumps out.
  17. Morphy Richards Iron Teardown: 步骤 17 中的图像 1,1
    • Remove the screw (circled) this will lead to the separation of the base and the top.
  18. Morphy Richards Iron Teardown: 步骤 18 中的图像 1,1
    • Remove the top of the iron to reveal the under parts.
    • Now remove the rubber seals from the plate.
    • Take out the screws linking to the stainless steel base.
  19. Morphy Richards Iron Teardown: 步骤 19 中的图像 1,1
    • Remove the terminal block from the wires.
    • Next take off the black section of the iron.
  20. Morphy Richards Iron Teardown: 步骤 20 中的图像 1,1
    • Now remove the screws from the steel base.
  21. Morphy Richards Iron Teardown: 步骤 21 中的图像 1,1
    • Next remove each individual part ( mostly wiring)
  22. Morphy Richards Iron Teardown: 步骤 22 中的图像 1,1
    • All parts at the end of the process.
RIchard fox
于03/17/10注册
269 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 98
总计 32,145
