跳转到主内容
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
DS Lite randomly dies. Replaced batt. No diff. Help.
Don't think it's worth returning my son's DS Lite to Nintendo for a $75 repair job, but would like to fix if it's not impossible. Is this common? Is there a fix? Thanks so much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
It simply turns off in the middle of games. Don't think it was dropped. Likewise spilled. Hmmm.
完成的
What happened when it first started? Was it dropped, liquid split e.t.c?
完成的
添加一条评论
5个答案
已选择的解决方案
Will it work reliably motionless, say running on a flat surface with no one touching it? If it does, you likely have a faulty ribbon cable in your hinge. Once they get touchy, they get so twitchy as to be unusable.
We fix those by replacing the entire top half of the DS, hinge top screen and all. Going inside the hinge is VERY labour intensive. Plus that twitchy ribbon cable is wave soldered to the top screen anyway, and cannot be removed from it.
Hopefully I'm wrong, because that is not an easy fix, and requires a donor DS Lite.
Good Luck!
这个答案有帮助吗?
得分 3
添加一条评论
Does it get very hot or absolutely anything out of the ordinary?
If not, it might be a very internal problem such as intermittent circuitry or motherboard. I think you would struggle to find parts for this and a fix by nintendo might be the best option if you want to keep the same unit
这个答案有帮助吗?
得分 2
添加一条评论
try cleaning the battery contacts
这个答案有帮助吗?
得分 2
添加一条评论
I have repaired quite a few DS's and I only came across this once. From what I've read there is a hairline fracture in the board, solder, or a main chip somewhere and when you put pressure on a button things flex and the DS turns off.
这个答案有帮助吗?
得分 1
1条评论:
I can verify what Little Chris said. I had this same problem and replaced the main board. Problem solved.
完成的
添加一条评论
I have a couple od ds systems and i heard that there might justbe wire damage. Basically the wires from the battery and the main part of the ds arent getting all the electricity it need to stay on. So when you charge it it will only get charged a little bit. It could also be what Little Chris said and theres a hail line fracture some where. But both of them could be the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo Furioso 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 12,771
