跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Error -1 iPhone 7 plus
a customer brought in a iphone 7 plus for a screen repair, but it had a broken lcd so i was unable to test it before i opened it. (note ive fixed about 30 7/7plus without issues.) anyway after installing the new screen I found the phone lagging and freezing up. but it wasnt my screen because the power button was also lagging and when i opened voice memos the record icon was unable to be pressed, also i only use oem apple lcd replacement parts, refurbished by myself so i know they arent fake. anyway I tried to restore the phone to see if that would fix it because i know there have been alot of issues with ios11 and im getting error -1 and now the phone is stuck in recovery mode...if tried updating/and restoring in dfu still not working. another note i tried both itunes and 3utools. when i flash on 3u i can see that it fails at 80% when trying to flash fuddata.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Will jailbreaking at least get it running? I don't care if I can't make phone calls
完成的
Replacement U3601 will solve the problem
完成的
Евгений Сухарев excellent bro .
i am at turkey . everytime you can take free beer by me
完成的
添加一条评论
4个答案
最有帮助的答案
Change IC u3601 and flash firmware again
这个答案有帮助吗?
得分 2
1条评论:
I hope I’ve seen your comment earlier, so it would save me hours of checking and fix.
完成的
添加一条评论
This is a pretty old error code. Try this
https://m.youtube.com/watch?v=8OYjEP8xtB...
这个答案有帮助吗?
得分 1
5条评论:
Lol its an iPhone 7 plus on iOS 11.. I highly doubt that program is even compatible.
完成的
Any luck on this !?also got the exact same problem and I'm there's no one here that can do micro soldering
完成的
@theimedic -- HEY How's it going, long time no see. You Ok?
完成的
It was audio ic
完成的
How to fix this? Thanks
完成的
添加一条评论
This is the classic error code for baseband issue now recalled by Apple on iphone 7 Model A1660 only. You need to take it to a real Apple store and they will send to Apple to determine replacement eligibility.
https://www.apple.com/support/iphone-7-n...
这个答案有帮助吗?
得分 0
添加一条评论
iPhone error 1? Joyoshare Ultfix can help you repair it without data loss. I used it to do the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lukerockhill 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 7,583
