跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 个问题 查看全部
PSP black screen, green light on and orange light blinkinv
Hi, I think the title says most of it. The screen lights up but there's no image, green light is always on and on the left 1st orange light is blinking.
I already tried holding HOME + L1 button, no reaction. Tried SELECT + START + TRIANGLE + SQUARE, PSP just turns on but no image.
Is there any way to fix it without pandora battery and magic memory stick?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Try removing your memory stick perhaps? The flashing orange light means that the PSP is accessing it, it could however be corrupted returning an error...
完成的
I have tried that several times. Tried, taking the memory card out, turn off the psp then take out sd card, and did many other make-believe solutions but all result to the same issue that I have
完成的
@alexniculescu i tried it didnt work ;-;
完成的
Hold all 5: HOME+SELECT+START+SQUARE+TRIANGLE and POWER IT UP.
完成的
添加一条评论
6个答案
已选择的解决方案
The problem was the memory card. I took it out and now PSP works.
这个答案有帮助吗?
得分 3
添加一条评论
Try taking the battery pack out, plug the PSP into the AC adapter like you would to charge it, turn it on, and if all goes well put the battery back in. Wait about 10 minutes with all plugged in then unplug the charger. If the PSP turns off then it is a battery issue. If it wont turn on even with the AC adapter plugged in it is an adapter issue
you can also try:
Press & hold the following buttons @ the same time:
Select->Start->Square->Triangle->POWER
这个答案有帮助吗?
得分 0
1条评论:
Dont Understand what you mean by take the battery out and plug back in
完成的
添加一条评论
To unbrick a PSP hold all 5: HOME+SELECT+START+SQUARE+TRIANGLE and then POWER IT UP.
Sony start-up screen should appear in about 3-5s.
这个答案有帮助吗?
得分 0
添加一条评论
Same thing was my battery had to take it out working without it just needs charging
这个答案有帮助吗?
得分 0
添加一条评论
I took the battery pack out and I had the ac adapter plugged in the whole time the green light came on for a second and then turned off. And it was on a black screen the entire time.
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue today and I did like the short show button and home and then the power button it’s worked for once and now it doesn’t work anymore. Can somebody help me?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tomasz Videos 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 68
过去 30 天: 282
总计 20,258
