跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 个问题 查看全部
Change the logic board from (A1418/EMC 2805) to a (A1418/EMC 2833)
I have a iMac 21.5" with a faulty (A1418 EMC2805) logic board.
I've been offered a iMac with a broken screen/case, is it possible to change the logic board (A1418 EMC2833).
thanks mark
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
The A1418 series: 2012 21.5" iMac's
完成的
添加一条评论
2个答案
最有帮助的答案
Yes. The A1418 is the model number. The EMC differentiates between different configurations.
这个答案有帮助吗?
得分 3
添加一条评论
The 2805 board is shorter and the chassis mount are in a different position.
These can be snapped off and glued to the desired position.
The SD C4 display panel has a different back light cable but will fit.
We have had issues withe C4 panel not working with other boards
这个答案有帮助吗?
得分 -2
1条评论:
Look again Peter! These are very different displays and not compatible!
- iMac 21.5" 1.4 GHz Core i5 (Mid 2014) - 2805
- iMac 21.5" 3.3 GHz Core i7 4K (Late 2015) - 2833
The Mid 2014 display won't work as it can't push 4K the newer system offers !!
完成的
添加一条评论
添加你的答案
mark walsh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 421
