跳转到主内容
加入维修社区 - 创建账户
Toshiba Satellite C850 发布于 2012 年,是一款 15.6 英寸的笔记本电脑,提供 AMD 或 Intel 处理器可选。它配有 USB 3.0 接口,并可配置最高 1TB 的 HDD 硬盘和独立显卡。
Is it possible to install a SSD (Solid State Drive) into Toshiba C850?
I have a Toshiba Satellite C850 and wondered if it is possible to install an SSD and whether or not it will effectively improve performance speed. Would RAM need to upgraded at the same time?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Si, yo tengo la misma laptop y le cambie el HDD por un SSD de 500 Mb, cambie la memoria Ram a 2x8 16 Gb, elimine la unidad de disco y pasas el HDD en su lugar con un adaptador, asi tienes dos discos C y D, instala Windows 10 y arranca en 30 seg. Te lo recomiendo
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
You can install a new SSD into your laptop. Use this YouTube video as a guide.
Upgrading your hard drive to an SSD will indeed boost the performance of your laptop, especially when it comes to loading stuff. Like Windows should load up very fast, in a matter of seconds, other programs, like Google Chrome and Office too. It will all feel a lot smoother, as the computer has to spend less time reading data from the drive.
Upgrading to an SSD does not mean that you need to upgrade the RAM too.
Your overall performance however also depends on the other components. Depending on the amount of RAM and on the CPU that you currently have installed, upgrading the RAM would or would not make sense.
If you currently only have 2GB of RAM, sure, go ahead, make the jump to 4, 6 or even 8. 2GB just won't cut it in 2017. If you have 4GB but a weak processor (like a Celeron o Pentium from 2013), adding more just wouldn't make much sense.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lisa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 4,022
