跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Could not activate iPhone server cant be reached after factory reset
Im so hopeless right now please help is my 5s blocked ?
Im running ios 11.0.3 i factory reset my iphone and suddenly it wont activate i try using itunes it goes error changing sim nothing works in fact even no sim on the phone it still says could not activate iphone because apple server cant be reached etc.
What should i do i tried downgrading it on lowest version possible which is ios 11.0.1 nothing works still error
What to do i dont have money to buy new one
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
已选择的解决方案
What error message are you getting from iTunes?
In the meantime, I would try another Lightning cable and possibly another computer if you have access to one. Also, remove the SIM card and clean it with isopropyl alcohol (rubbing alcohol will do but if you have higher grade, then use that). Once it's dry, re-insert it.
If that doesn't work, I would wait a while, perhaps there is a problem with the connection to the activation server. Maybe re-start your computer or network connection.
这个答案有帮助吗?
得分 2
4条评论:
Error then numbers ok i will try cleaning the sim it just says on the iphone itself not on itunes could not activate because the server cant be reached etc fpr 2 days on itunes didnt work even on other pc
完成的
Nothing works
完成的
Im dead even technicians here dont know how to solve it they try putting interposer chip still doesnt works restoring etc nothing works the server is stable maybe my iphone is blocked by the server ?
完成的
@kobexkyrie What error number are you getting?
完成的
添加一条评论
My 1st time of even owning an iphone and i only have it as i was given an iphone 5c and i reset it thinking i`ll start from scratch and i have exact same problem!This is why i have always said i don`t like them because of the complications!It`s just another way for apple to make money in my opinion and in the meantime i`m without a phone!Thanks apple!
这个答案有帮助吗?
得分 1
添加一条评论
Connect your iPhone to iTunes with an active Internet connection. See if iTunes will activate the phone.
You may need to restore to 11.2.1 via iTunes for this to work. Do a restore, not an Update.
Alternatively, I think the question that is avoided is "Who is your carrier?" Some MVNOs need to be called, contacted via live chat, or emailed and need to be live on hand while the activation occurs.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fixie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 3,849
