跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Difference between two replacement screens
Hello,
Anyone knows what's the difference between these two products?
1. "iPhone 6s Plus LCD Screen and Digitizer Premium": https://eustore.ifixit.com/en/Parts/iPho...
2. "iPhone 6s Plus LCD Screen and Digitizer Full Assembly":https://eustore.ifixit.com/en/Parts/iPho...
Apart from the word "premium" in the first one, there is no apparent difference.
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
There are two things to note here. You are comparing a premium screen with no small parts attached to a regular screen with small parts included (camera and sensor flex). Some people like to have the camera flex included as that makes the repair simpler. However, you are forsaking an original quality camera and flex for an aftermarket one. I would stick to a screen without the camera so that I can keep the original goodness.
The premium screen uses a cold glue process for securing the frame to the glass and should feature OEM quality flexes and LCD. The regular screen is aftermarket quality so it will have aftermarket flexes and LCD. I don't know if the iFixit regular screens uses a hot glue process or not but that is a lower quality process.
Either way, iFixit stands behind their products so if you do have any issues, they will cover it.
这个答案有帮助吗?
得分 3
1条评论:
At my shop I prep my displays to have the cameras and backplates on them already. Turns my repairs into five minute average. It's much easier, but what you're actually paying for is those extra parts. Which cost money
完成的
添加一条评论
Sure there is, look at the prices! I'm sure there must be quality differences or one's an OEM.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
darcode 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 12
总计 1,113
