跳转到主内容
加入维修社区 - 创建账户
第三代 Surface Pro 平板,发布于2014年6月20日。
Surface pro 3 won't turn on anymore.
As of last night, my surface shut off right after I turned it on. I was unable to turn it back on, even after trying all the fixes suggested on the microsoft support site. I took it to a local computer place and they said that I would have to take it to a microsoft store to fix it because it was likely a hardware issue.
Now I'm pretty sure I bought this thing refurbished, so it doesn't have a warranty. Not to mention the drive to the nearest store is really far so I'd have to plan a day to go, and probably pay a ton between gas and parking. I feel like actually going to get this fixed isn't worth it. I'm gonna try calling a couple of other places to see if they can retrieve my files, but otherwise I wanna try fixing this myself if it's actually feasible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@osubb let us know what the fixes were on the Microsoft website. What have you checked? did you check to make sure that your charger works and that you have a good cable? Did you check to make sure that the jacks are okay and not bend or contain debris?
完成的
添加一条评论
2个答案
I think I am having the same issue, did you find anything out?
这个答案有帮助吗?
得分 0
添加一条评论
No luck, unfortunately. I took it to have it looked at, but they told me I would need to replace the motherboard (which would be a few hundred bucks). And since I had gotten it refurbished, I was not able to access my files since Surface comps come with encryption. I just had them remove the chip with all my files and got rid of the thing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ogre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 534
