跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your LG TV.
LED Tv screen turned grey
My 1.5 years old LG TV ( 65uf6450) suddently turned grey\White noise (without the noise) while watching netflix. The tv menu works youtube menu and netflix menus work great, i can select something to watch but when it starts the picture turns static grey (no video) the noise is perfect, subtitles are there and i can see the picture for fast fowarding and how to skip the adds in youtube.
I called LG and made me reset the tv and unplug it, but because the warranty is one year they didn't care, they offered to send me someone at my cost. Any one experienced this before, and know how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
We need a bit more info to answer this. How many devices are plugged into this TV? If what you are talking about is going through the same wire, then I would suggest replacing the wire ( I presume HDMI).
完成的
Only thing pluged in is a sound bar and I've removed it to see if it was the problem but it still does it. I’ve disconnected my ipad and iphone to make sure there is not interference.
I can access youtube menu and select tiles but when i go to play a video my screen turns grey\white kind of like the old tv’s when u didn’t good reception from satelite or cable.
完成的
@lgtv65 have you tried all the other inputs? HDMI Component Coax etc. This is very important to test since your error maybe isolated to one input. Disconnect absolutely everything and only select one input. Usually when your on board menu works but not your image it is a main board issu. So you do want to check by removing the back of your TV and check for obviously damaged components. Leave this until you check the inputs first. Post some pictures of all of your boards with your question. That way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
完成的
So i called costco and after being transfered a bunch of times they finaly decided to send someone next week. Thank for the help but now i will just wait for them to deal with it.
完成的
John did they tell you what was wrong I have the same issue
完成的
显示更多的3条评论
添加一条评论
2个答案
最有帮助的答案
John,
I had the exact same problem on the exact same model. The problem was the main board. I ordered a new on from Electronic Fix out of Tampa, Florida ($160 USD) and replaced this myself, takes about 30 minutes to hour to do. This fixed the problem.
Apparently this is common problem with these tv’s, probably due to insufficient cooling. I cut a small 4” x 4” hole in the back of the tv panel and glued a small USB fan over the opening so the fan is pulling the air outward. The nice thing is the mounting location is close to the USB port which I don’t use, and also the fan will only run when the TV is on, so it worked out pretty good. We’ll see how long this board lasts.
Cheers,
Eric
这个答案有帮助吗?
得分 2
添加一条评论
It could be a possible fuse that has blown out or a capacitor or a certain video board needs to be replaced i well get more information and let you know when i get back to you
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 21
总计 35,041
