跳转到主内容
The 2003-2005 Pontiac Sunfire is a more streamlined updated version of the popular car.
7 个问题 查看全部
Why is there gas spraying into the tube that leads to my air filter?
There is a small black hose that leads to the tube my air filter is in & the other end is on a cyndrilical metal like item...something to do with fuel I'm guessing. Gasoline comes out the end that goes into the tube that leads to my air filter, my car popped & started smoking the other day after I tried to start it, I took the air filter out, the small black hose off & plugged it up...help! What is the metal cylinder shaped item that the other end of the hose i's hooked up to called?
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@bsrigamarowe post some good pictures of what you are looking at with your question. That will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that.
What exact year is it and hat engine size does it have?
完成的
添加一条评论
1个答案
已选择的解决方案
The only line that should be attached to the air intake is the pcv exhaust . Are you sure this has gas coming out or is it oil . you may need to replace the pcv valve if your getting excessive blow by. The cylindrical item is the PCV valve . Hope this helps
这个答案有帮助吗?
得分 2
2条评论:
It is definitely gas, my air filter was covered in it which is probablying why it popped & was smoldering when I tried to start my car. When I had the hose attached it was my car had a difficult time starting, I had to pump on the gas pedal & when I'd let up it'd start. Now that it's disconnected it starts just fine.
完成的
@bsrigamarowe could you post some photos of the part your talking about
在已经存在的问题里加入图片
完成的
添加一条评论
添加你的答案
Bernard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 44
总计 2,260
