跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Will the MacBook Pro SSD work in my Desktop system?
I want to use the SSD from the MacBook Pro mid 2012 and put into a desktop. Can I do this?
I also have a MacBook Air mid 2012 too. If that has one as well that would be great.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What desktop? Make, model # and year.
完成的
Oh, it is a system that I want to build the motherboard supports M.2. https://www.amazon.com/gp/product/B01MR3...
完成的
添加一条评论
1个答案
已选择的解决方案
Since the M2 blade do not work without issues in Macs, I doubt the Apple blades will work in PCs. Besides Apple has four different types of blades now.
What I do with old blades is put them in the proper OWC Envoy external enclosures and use them for diagnostic and installation drives.
这个答案有帮助吗?
得分 3
2条评论:
What about the macbook air mid 2012?
完成的
The best way to figure this out is to review the system specs across the systems in question:
- MacBook Pro 15" 2.7GHz i7 (Mid-2012)
- MacBook Air 11" 2.0 GHz i7 (Mid-2012)
- MacBook Air 13" 2.) GHz i7 (Mid-2012)
You'll see all three use a SATA III (6.0 Gb/s) interface so you would think it should work based on the specs but there is an issue of size! The Air's use a long narrow SSD whereas the MacBook Pro uses a short and wide unit. So sadly the SSD won't fit across these systems!
Reference: SSD Upgrade Kits For MacBook Pro Retina (2012 - 2013) & 120 GB SSD Upgrade for 2012 MacBook Air
完成的
添加一条评论
添加你的答案
Raul Sanford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 764
