跳转到主内容
The BLU Vivo XL2 is an Android smartphone produced by BLU, an American consumer electronics company. The XL2 was produced through a partnership between BLU and Vivo Communication Technology Co. Ltd., a Chinese technology company. The BLU Vivo XL2 was released in January 2017.
Why does my BLU vivo XL2 keep exiting applications?
My phone all of the sudden has started acting weird, with apps closing, pages turning, and the screen not responding to my touches but not crashing. Nothing has happened to it recently and has 0 damage to it. All of these lead to a possibly broken sensor, but I'm believing it has something to do with the software due to zero damage to the phone or anythign else and it just acts crazy.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
8条评论
Mine is doing this too and it's extremely frustrating, when I'm typing out a message it goes unresponsive and starts vibrating. I literally got my XL2 in October 2017 so it hasn't even been a year I'v e had it
完成的
Send it back to them Angel. I did and they just sent me a new phone (different model completely) I believe its an issue they are aware of and don't know how to fix. Contact them, (they will tell you to reset your phone to factory settings) tell them it didn't work. They will ask you to send it to them. And then they will send you a new phone hopefully. My new phone is working great with no problems so far.
完成的
Did you send it to Amazon or blu?
完成的
hello:
I sent it to BLU (RMA 067457) last September and they did not do anything to the phone. I complained and they did not want to give me a new RMA since I was not living in the US. I showed up in BLU Offices in Doral (in a stop from Mexico) and they were not able to even receive the unit. Very bad support
完成的
The same thing happens to my phone. When I first got it these problems did not occur but I will be in a app and he phone will just start vibrating and not responding to my touches
完成的
显示更多的3条评论
添加一条评论
10个答案
最有帮助的答案
My phone started doing this a couple of months ago and I don't know what else I could do to fix it
never buying Blu again
这个答案有帮助吗?
得分 4
添加一条评论
Heads up: it's looking grim.
I found this thread and this other question (Why does my phone randomly vibrate & start exiting me out of apps?) with people having the same issue. So far, I have not seen a solution. However, you might want to explore this website. It appears to be unofficial developers seeking to fix things, but I'd advise reading their fine print for yourself. Since I had to look it up myself, here's an explanation of ROM.
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
Try removing the silicone case and screen protector. That fixed it for me.
这个答案有帮助吗?
得分 1
2条评论:
I have same issue, I will try removing protector and case. Did you find any alternate case and protector to keep phone safe?
完成的
I did that too but it didn't work
完成的
添加一条评论
My phone does the exact same thing. It will be fine for months and then it will exit apps, not respond to touches etc.restarting it usually helps in the moment. I took my screen protector off and the case. I'm still having the problem. Bought the phone off Amazon but I'm at the point where I might complain directly to BLU. Other things I've noticed is my internet doesn't always Connect. I end up using so much data because it will say I'm connected but nothing will load. Also my blutooth doesn't connect always. And the speaker phone on this phone is quieter than if I just have it regularly and listen from afar. Not impressed. Definitely not purchasing again.
这个答案有帮助吗?
得分 1
添加一条评论
My phone used to do the same for weeks and now it seems to be fine for the last ten days. Have anyone realized the same, I mean, the phone is working properly now out of nowhere?
这个答案有帮助吗?
得分 0
添加一条评论
My phone does this on and off. It will do it all day one day, and then the next work perfectly. I finally sent it into BLU to see if they'll fix it. All they told me to do was a factory reset, and it didnt work.
这个答案有帮助吗?
得分 0
添加一条评论
I keep doing the hard reset, disabiling apps, getting frustrated. If I had money I would ditch this on and get a note 8.
This isthe 4th time I e
这个答案有帮助吗?
得分 0
添加一条评论
Hi i have Condor P8 lite … and i think it is Vivo xl2 .. this happens to me too .. i thought it was hardware thing .. it costs a bit to change the display entirely .. so i rooted my phone and deactivated the hard buttons and activated the soft one .. then one day i got bored and found out that there was a MIUI9pro custom rom for my phone so i tried to flash it .. something went wrong and i got a bootloop .. i couln’t shut it down to flash it again .. so i had to open the phone and unplug the battery then plug it again .. and i flashed MIUI9 (it is amazing btw) xD and unexpectedly .. the problem was solved .. after 3 weeks .. today i had the same problem again .. randomly exiting apps etc etc .. so i did it again .. unplug the battery the plug it again .. not take it out ;. just unplug it .. and it is half a day and the problem is gone now …
这个答案有帮助吗?
得分 0
添加一条评论
I have 2 of these phones in my family and noticed the problem occurs especially whenever the charger is inserted. Solution I think is to replace the USB charging connector. I am currently searching online for a replacement part and will update if I found it and do the replacement.
Update (05/31/2019)
I have tow of this phone in my family and noticed the problem is amplified when the phone is being charged and handled. I think there is a defective charging port that needs replacement. I am now searching online foe a replacement part. If anyone fine a supplier, please post website address. I will followup if I am successful.
这个答案有帮助吗?
得分 0
1条评论:
Updates? My vivo xl will not continue to run apps that are not currently being displayed. Also my Bluetooth is constantly resetting and/or disconnecting so I need to reboot to get it to reconnect. Occasionally (often enough) the buttons won't respond for twenty seconds after I close an app/open home page.
完成的
添加一条评论
Clean the screen. Had similar problems, cleaned the screen, problem disappeared.
这个答案有帮助吗?
得分 0
2条评论:
What be do you mean by clean the screen?
完成的
Further to my last post, after a long time
On line my phone goes crazy, being in quarantine my hotel had a fridge so I put it in there to see if it was a heat problem as the phone near the camera was hot.
Maybe 15 mins in the fridge and all the problems disappeared. It's an over heat problem. Try it!.
Of course it will start to heat up and all the same issues will come back.
完成的
添加一条评论
添加你的答案
Chase Holdernesse (Crysisops9) 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 60
总计 5,924
