Why Does my screen blink intermittently? APPLE CANT FIGURE IT OUT!
Why Does my screen blink intermittently? APPLE CANT FIGURE IT OUT!!
I've had this problem come up recently. This was a problematic MBP mid 2012
The Logic board was replaced in warranty as one of the memory slots doesn't work so running single slot.
Symptoms:
- Screen blinks to black and the ability to move the mouse in that instant is lost.
- Screen blinks on battery and magsafe power
- No change with movement of the LCD screen
Update (10/10/2017)
Here are two video clips. One of them shows how it blinks when I'm using it, and the other shows it blinking on the reboot page.
4条评论
If you connect it to a external monitor/tv does the computer work on the external monitor or does it do the same blinking?
由 Anthony 完成的
apple tried to connect it using the thunderbolt and apparently my thunder bolt was not working?
由 Carlos Adamez 完成的
Saw the video now. Seems like it is loosing backlight voltage. Should be an easy fix for a board repair shop.
由 TCRS Circuit 完成的
Contact Apple Support
由 Vasapol Aurean 完成的
