跳转到主内容
发布于2017年7月28日,新 Nintendo 2DS XL 是 Nintendo 2DS 掌上游戏机的迭代机型。
Why won't my device turn on?
Even when I charge my device, it won't turn on. What could be the issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
Mines does that to I charge to fill battery and it does not come on
完成的
添加一条评论
2个答案
最有帮助的答案
The device's battery may be worn out and unable to recharge. To replace the battery, you will need to remove the bottom panel of your 2DS XL Device. After the panel is removed, you will have access to the battery and can replace it. For further help with replacing the battery, refer to our battery replacement guide.
这个答案有帮助吗?
得分 2
添加一条评论
try to charge the nintendo. Its probably out of battery.
try to go to the service centre. They will tell you what's the problem
try to change the battery.
or, try to service the screen. It may be broken.
这个答案有帮助吗?
得分 0
1条评论:
if the screen(s) were broken the blue light would still turn on, and you would hear sound
完成的
添加一条评论
添加你的答案
Sebastian Elizondo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,986
