跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
How to fix screen flicker MacBook Pro (Retina, 15-inch, Mid 2015)?
Screen started on permaflicker yesterday. Had intermittent issues for a day or two prior. No know drops or blows to the maching. Display on external monitor is fine, screenshots do not capture any of the dipslay issues. Seems to be LCD / hardware related I think. Got tools on the way to crack into it and see if anythings loose. About 6 months out of warranty. Any other suggestions?
http://jciproof.us/7ZzzDF/lElIRHFT
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
FOUND A SOLUTION HERE:
https://youtu.be/plT6vW6JB-Q
完成的
添加一条评论
2个答案
已选择的解决方案
Oh Boy you got it bad!
Your issue is likely the lid assembly got a good bang damaging it. To be sure your image should be clear using an external display. If thats the case, follow this IFIXIT guide: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement and here's the part you'll need:
Or from here:
MacBook Pro 15" Retina (Mid 2015) Display Assembly图片
产品
$519.99
这个答案有帮助吗?
得分 2
添加一条评论
Hi there! I think I have the same issue on the MacBook Pro (Retina, 13-inch, Mid 2014) and I want to see if I can fix it myself. Is there a guide for my model?
这个答案有帮助吗?
得分 0
1条评论:
@pavlo15914 - Here you go! MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
Here's the listing for all our guides for Mac stuff Mac so you can locate what you need for anything else.
完成的
添加一条评论
添加你的答案
Curtis Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 20
总计 57,519
