跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Replacement front panel assembly
After the second full panel replacement, the glass has again cracked.
When attempting to reseat the loose home button glass cracked.
First time was due to flex stress at the cable attachments. Seems regardless of how well you follow the instruction that corner does not want to adhere properly.
Looks home button was due to this poor adhesion.
What is the fix for this.?
Why does this seem to be a systemic problem with this replacement panel?
Two panels within two months and they both have the exact same issue.
At this point I’m in half the cost of a refurbished pad. Seriously considering a refurb rather than try a third.
Advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
One issue with the repair guides, especially for iPads, is that they don't show you the best practices for re-assembling the device. While you can reverse the steps, there are a few gotchas in the process. Every iPad has it's idiosyncrasies.
The Home Button flex has to be positioned such that it folds properly, towards the inside, without kinking. Look at Step 40 of this guide. Likewise, the digitizer flex cable on the air requires a special inside-out kind of fold otherwise it doesn't lay flat and puts upward pressure on the digitizer. Zoom in on Step 43 of the same guide to see what it looks like.
The final thing to check is the condition of the housing. You don't want any damaged corners. Sometimes it doesn't seem like much, other times it looks like this.
The bottom line is that even a few tenths of a mm can exert pressure on the glass and it will crack the first chance it is stressed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris Goodwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 75
