跳转到主内容
加入维修社区 - 创建账户
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Prohibition Sign on Start Up
iMac won't start up and it shows the "Prohibition Sign" on start up. I went into recovery mode and to disk utility and it doesn't show my fusion drive and it shows no information what so ever. Can anyone help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
You won't see the Fusion Drive under Disk First Aid, You'll see the discreet drives (HDD & SSD) that combined make up the Fusion Drive set. If you can't mount the drives then you have a deeper problem!
At this point you'll need to use the command line interface of Core Storage following this guide: Fixing a Mac Fusion Drive that Disk Utility can’t erase
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like your fusion drive has failed.
Try to get ahold of another mac and make a bootable thumb drive for any OS X installer. See if your iMac will boot from this thumb drive. This would verify if your disk has failed or not.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Name 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 11
总计 279
