跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Don't know if screen broken or something else...
Hello,
I dropped my iphone 3s once and no more images appears in the screen.
Some time later I put it to charge and screen light went on, but it shows only some kind of pixel pattern in grey, with vertical white tin lines.
At this stage I cannot tell what is wrong. Screen seems not cracked, since backlight went on but nothing seems physically broken.
The only thing I can do is to press both buttons at the same time and screen goes black like it turn off. When I turn it on again, I get some weird horizontal lines showing on and off for some seconds, then some color randomly placed lines and then a nice white screen for some seconds before the weird horizontal lines dance begins again, like and old tv with a bad antenna.
I will like to have an opinion in this, in order to know what can I do with it since I hate to trow away stuff that can be fixed.
I took off the screen a little bit and the connector #1, and the screen goes black and you must 'turn on' the phone again. that connector is a little devil, who will umplug itself very easily. But with the connector right on place the problem is the one described.
The others connectors, I didn't remove. They seem well placed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
coursparis this "some kind of pixel pattern in grey, with vertical white tin lines" is pretty indicative of a broken display. Here are the guides iPhone 3G needed for the repair. To find a replacement display will not be easy or cheap.
这个答案有帮助吗?
得分 2
4条评论:
with grey I don't mean lcd liquid, just a degree of very light grey in a perfect pattern. Sometimes is not exactly grey but light blue...
完成的
coursparis add an image of what your screen displays with your question. Use this guide 在已经存在的问题里加入图片 for that. It will allow us to see what you see.
完成的
done! thanks!
完成的
I would advise you to repair phone in a workshop or find the skilled person on this website
完成的
添加一条评论
Nobody? please......
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
coursparis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 218
