跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
How to fix a stripped screw?
So I have an iPhone 7+ I'm repairing for a customer and one of the star shaped screws on the bottom of the iPhone is stripped and no matter what I do I can't get it to come out, at one point it was turning but it wasn't unscrewing. Any tips to get that screw out?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I am assuming that you are using the correct screwdriver for the screw (pentalope type) and that the screw spins in the hole, but wont come out.
No fun! If you haven't solved this yet, here is an idea/solution.
Try using a strong magnet on the tip of your screw driver/ on the screw directly to see if it will pull out - Maybe it wont work because of the black gasket material on the screen legs to stop ingress of liquid from the screw holes. If that didn't help, check out the next part.
Our favorite friend, Superglue! This will probably destroy your pentalope screwdriver and screw in the process So what we are going to do is glue the screwdriver to the screw to let us physically pull it out.
Add some super glue to the tip of your pentalope screwdriver, not to the screw its self. Now, don't add to much, we want a microscopic drop on your screwdriver tip. Not the side, but directly the tip. - If you do add to much, you just glued the screw into the phone - and that is not good at all as you can imagine.
Stick the screwdriver into the screw nice and strait and let it sit without moving it for a few min - maybe 5 min to be sure- I have had superglue take way to long to set - but that should be plenty of time. The screw should now be glued/connected to your screwdriver, so you should be able to gently pull out on the screw away from the phone with no problem.
You might be able to retrieve the screw and save the screw driver with Acitone (fingernail polish remover) if you wish, but no promises.
Good luck!
这个答案有帮助吗?
得分 3
添加一条评论
Take your screwdriver for it and a small hammer and gently tap on the bottom of the screwdriver with it positioned over the screw and proceed to slowly turn it when pushing down it worked for me.
这个答案有帮助吗?
得分 2
1条评论:
This worked great!!!!! Thank you so much!!!
完成的
添加一条评论
i just got mine from this site cuss its seemed like it was better quality. works fine. cuss the chinese one that i used before was junk.... it just stripped lol
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nina Borseth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 17,486
