跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Replacement Microphone for EMC 2134
Hi,
I replaced my disc drive on my 24" iMac 2134 - in the process I managed to break the microphone. Does anyone have suggestions as to what would be an acceptable replacement? Does iFixit sell one? Or is it possible to repair it? Basically I removed the two wires from the circuit board. Suggestions would be much appreciated.
Thanks,
Paul
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I'm pretty sure it's built into the camera board, you don't see the mic replaced often. If so here's the part: http://www.gainsaver.com/Catalog/Detail....
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your response but that is a link to the camera portion. The mic goes in through a different cable which has an detachable part that when you take the top case off comes off with it. Unfortunately I destroyed the connection when I removed the case. it looks something like this http://www.gainsaver.com/catalog/Detail.... but for the Intel 24"EMC 2134. Any other ideas? Thank you
完成的
I can't find the mic or the part number for it. The closest I could get is the cable part number 922-8158 & 922-8155
There a chance that a MacBook Pro mic would work. Here's one: http://www.usedmac.com/catalog/product_i...
完成的
添加一条评论
You can buy the imac bezel bc that part of the Mac comes with the microphone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Sednaoui 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 3,820
