跳转到主内容
The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
Is it possible to replace the touch screen only?
I have a cracked touch screen on my Asus Zenpad 3S 10 Z500M but the display is not affected. I only see the whole assembly for sale online so I'm presuming this tablet is one that requires the whole assembly (expensive) to be replaced. Is it possible to replace the screen alone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
Hi
Asus parts (click on LCD panel link in middle of page in link) doesn't list the digitizer as a separate part so I think that your assumption that it requires a whole assembly is probably correct.
完成的
Be warned that the glass (digitizer) can be purchased separately on e-bay. However, it seems impossible to remove the glass from the LCD panel. This is likely why Asus does not list the part(s) separately, and buying the glass separately may be worthless.
完成的
I have a ASUS ZenPad model P027, but I measured it across, and it measures less than 9.5 inches. The thing that bothers me is that the spec says 9.7 inches. Is that correct?
完成的
Cracked screen touch screen not working
完成的
添加一条评论
3个答案
最有帮助的答案
yes it is possible to do the glass only but it is not a simple job, i highly advise purchasing complete as glass only requires specific tools that you may or may not have access to and the chance of breaking/burning the lcd is very high
这个答案有帮助吗?
得分 2
1条评论:
I found it is better to just buy the screen/digitizer assembly. It is not too terribly expensive and available through eBay.
完成的
添加一条评论
A lot of repair options are POSSIBLE, but some turn out to be not PRACTICAL.
Most experienced electronics repair shops would still purchase the more expensive full assembly: cover glass, digitizer and lcd in one. Separating the old laminated parts is too time consuming and risky for a single job. Glass-only repairs only make sense when refurbishing thousands of screens at a time, so that you can afford to by the expensive tools required to do it right.
The factory vendor posting on eBay or AliExpress does not care if their glass-only part is a practical option for their customer. They just want to sell as much glass as possible.
Think of the windshield on a car. This is made of multiple layers of glass and plastic all glued together. If you cracked the top layer of the windshield only, you would never consider stripping it down to preserve the bottom layer by replacing only the top. Anyone would choose to simply buy a factory made assembly of the whole windshield.
这个答案有帮助吗?
得分 2
添加一条评论
Yes it is possible. I removed mine originally before I realized I needed both. Still got that glass. But its for a ZenFone 5.
I also need to replace my screen/digitizer for my ZenPad s3 (10) z500m. But the cost is ridiculously high! Unless someone knows a cheaper source. Thanks
这个答案有帮助吗?
得分 1
4条评论:
Hi @groggzilla ,
Just so we know how high to set the bar.
Is this too high?
Cheers.
完成的
is thre a little cheaper sceen plss help
完成的
and is there a home button with fingerprint replacement too?
完成的
Did you manage to separate the glass from the LCD? I was stupid buying the digitizer only and I cannot find someone who is capable of doing it :(
完成的
添加一条评论
添加你的答案
David Abel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 6,425
