跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 手柄的维修指南和相关信息。
Replaced joy-con shell; bungled joystick?
I did a shell replacement on my whole Switch, including the body and both joy-cons. Everything went great except for the right joy-con: I must have screwed up the joystick because now it’s permanently sending “joystick right” anytime it’s connected to my unit. The joystick itself looks just fine, it doesn’t look bent. The only thing I can think of is maybe I screwed up the ribbon cable when I plugged it back into the joy-con circuit board.
Has this happened to anybody else? If so, is there a fix? If not, is there a place I can buy a new joystick assembly for the right joy-con?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
I have a similar issue - try lifting the rubber flap that covers the Joystick guts (just under the stick). Then blast some compressed air into here and move stick blast, move stick, blast. See if that helps. Then run the analogue stick configuration from settings.
这个答案有帮助吗?
得分 1
2条评论:
How did you get the rubber cap back on? It won't fit in for me.
由完成的 分享
You list it back with two pins it will flap and stay back if done right. A little fiddly but if not you hold while someone else sprays
由完成的 分享
添加一条评论
添加你的答案
Ben Kreeger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 40
总计 2,947
