跳转到主内容
Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
45 个问题 查看全部
AF-P 18-55 lens autofocus issue
The lens suddenly stopped auto focusing. What may be the issue ? The camera is autofocusing with other lens but not this one. I have tried to clean it and re attach it but the problem persists.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
There seems to be an issue in the lens, since you have said you had other lenses that work (assuming they are also AF-P). Could see if the connectors are working correctly and are clean (check the camera’s as well).
Does the manual focus work at all? The AF-P lenses use a fly-by-wire system for the manual focusing, so if that does work, then it is likely the camera and/or lens has manual focus set, and the lens is communicationg to and from the camera, and the focus motor is working.
这个答案有帮助吗?
得分 0
添加一条评论
Same problem with my D5500 as well. It do not auto-focus
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
prabhuti samal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 1,163
