跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Avoid dust installing a new screen
Hello
I had to change my Iphone 3G screen after a white screen of death, and everything works fine. The thing is that after the replacement some dust is between the touch screen and the screen. I tried to clean it but without sucess, i cleaned old dust but i get new.
Is there any trick to avoid dust? or maybe a way to remove it, compressed air?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hey there,
A new screen as in the hardware screen or the cover screen that protects your iPhone from your finger prints?
If it is applying the screen to protect the actual screen from your finger prints, there is a website:
http://www.ehow.com/how_5942211_put-scre... (credits to them, I did not write this, although I wish I did =P)
If you're talking about the actual hardware of the iPhone screens: I suggest you take a look at:
http://www.wikihow.com/Fix-an-iPhone-3G-... (If in this case, you want a screen replacement)
iPhone 3G Troubleshooting (Some of the frequent problems that occurred on iPhone)
And there are also some resources about taking the iPhone apart and replacing it with a new screen on the ifixit.com
iPhone 3G的前面板更换
Things you might need to buy:
[关联产品丢失或禁用: IF137-007]
I am sorry I can't actually help out with my current resources, but If I am talking about something totally different, you can re-post your response and I will do some more research about it.
I hope I helped,
thanks!
Nonth =)
这个答案有帮助吗?
得分 1
添加一条评论
When installing a new screen its best not to remove any protective films untill right before you put it in.
I find that using a microfiber cloth tends to work best.
After wiping it down, keep it covered by the cloth, and then wipe the LCD with the another cloth.
Then (as i said above) give them both a quick wipedown and install them.
By wiping them both right before you close up the iphone you are making the time it takes for dust to accumulate shorter and therefore eliminating most of the dust under the screens.
Hopefully this will prevent any dust getting in, but its not fool proof. Its just alot of trial and error.
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
krasny oktyabr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 2,785
