跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
iMac wont boot up
iMac 27" Mid 2011 2.7ghz intel i5
EMC 2429 A1312
Hi,
I was on my computer and all of a sudden it shut off. I tried to unplug it plug it back in and waited for a bit, and I still get nothing, it won't boot up whatsoever.
My guess is that the power supply is dead.
I was just wondering what the part number might be.
ALSO, Will a 2009 iMac PSU 614-0476, work with my 2011 iMac?
this is the power supply I found on ebay that I'm thinking of getting
http://www.ebay.ca/itm/Apple-iMac-A1312-...
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Have you checked behind the back cover of the PC? Dust could be an option or a battery.
完成的
What diagnostic LEDs are you seeing?
Also: Won't power up and only 1 diagnostic LED
完成的
ok so, i unplugged it for a bit plugged it back in, it started, then it randomly shut off i tried turning back on it it wouldnt start. so i opened it up and cleaned out the dust, it turned on and it worked again for a couple of hours and then it shut off again. the computer shuts off and you can see everything go to the middle off the screen and then disappear, it wouldnt turn back on. it looks like the power supply might be faulty. whenever you plug it in the wall while its off and listen carefully you can hear a small buzzing noise coming from the PSU
完成的
Wondering how this turned out for you, Matt M? Did you keep trying to fix it or is it time for the scrap heap? I find myself in a similar situation. I have not opened mine up, but it has not turned on and won't turn on. I bought a new power cord to see if that was the problem, and it is not.
完成的
添加一条评论
2个答案
最有帮助的答案
Try to disconnect the power cord from the iMac and the wall and hold the power button for 20 seconds to drain any power on the board then plug the power cord back to the iMac and the wall and turn it on. If it doesn't power on. Post your serial number to find it here is the instructions https://support.apple.com/en-us/HT201864 .
这个答案有帮助吗?
得分 1
添加一条评论
I hope this helps with your iMac.
https://youtu.be/xYmtoaT9ImI
Best wishes!
这个答案有帮助吗?
得分 0
1条评论:
This is not a power button issue.
完成的
添加一条评论
添加你的答案
Mat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 953
