跳转到主内容
Various pc problems I have
First problem came a long time ago, my graphics card went completely kaput, which is such a long story to tell I can't tell you here.
But now bew problems have arisen, first my PC was shutting down and restarting out of the blue, but a Windows memory dignostic managed to hold it down until a few hours ago when I'm typing this, I tried to attempt to do the memory dignostic again but it unfortunately stopped, (atleast I thought it did)
And NOW it won't turn on at all, well, it does but my monitor light never goes blue and my PC doesn't make a beep noise, which it always does when I turn it on, but the lights inside the PC glow though, and the fans were spinning.
I cleaned out some of the dust in the PC itself all the while unplugging all the usbs that were connected to the back of the PC, and it turned on then but I didn't manage to hit F8 in time to get to the repair my computer menu.
And now it's back to not turning on to an extent again, please tell me what's happening, I'm really at my wit's end now.
UPDATE: After a waiting a while and another Windows Memory Diagnostic, my pc is fine again, but it could happen again, hopefully this is something some people are familiar with.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
This may be a power supply problem, one of the voltages is either missing or too low. There is also a signal called CPU Ready that tells the power supply that it is safe to turn on. You can try a volt meter to check the power supply output. If the power supply is good then the problem is either the system board or the processor.
完成的
Have you tried reseating the RAM DIMMs?
完成的
添加一条评论
1个答案
My first thought is a faulty power supply. As they age, they can deliver less power. So if your system peaks at 500 watts and your PSU is rated at 550, over time your PSU will be stressed as it can no longer reach it's rated power output and could fail, or even damage components in the system. If you can, try replacing it with a known good PSU. It's possible the motherboard has already been damaged as it's not powering on, so I'd not try again with that PSU.
这个答案有帮助吗?
得分 0
1条评论:
You mentioned a problem " a long time ago". Just how old is this system? Some basic specs and the PSU make / model would also help.
完成的
添加一条评论
添加你的答案
Ricard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 90
