Anyone know where the power on pads are? (MBP 13" Touch bar late 2016
Looking for the power on pads on a 13" macbook pro with touchbar (late 2016), anyone know where they are, or even if there are any ?
thanks!
If you are trying to boot the machine without using the power on button do the following:
Disconnect the mag-safe adapter, disconnect the battery from the logic board. Press and hold the power button for 5 seconds (this is not needed for the reboot but resets the SMC). Now plug the battery back in then the mag-safe and you should get a spontaneous reboot.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,990
3条评论
Looks like I have a dead logic board then. Many thanks for the advice.
由 glenn 完成的
What happened?
Apple may still fix it under warranty depending on whats wrong. Being such a new model they often will extend coverage a few months.
由 Dan 完成的
Sadly, Apple won’t cover liquid in the keyboard. I wanted to rule out the keyboard / power button and see if there was any life in the logic board.
由 glenn 完成的
