Certain app not being deleted.
I recently downloaded an app for my iPad 2, However it said i did not have enough memory on my iPad and now it wont go away even when i try to delete it.
Help will really be appreciated.
Thanks
I would try this:
• Connect iPad to Mac or PC
• Launch iTunes
• Create a full backup (do not back up or transfer apps if it asks)
• put the iPad in DFU mode
• install iPad's firmware in DFU mode
• restore from the backup you just made
What this does is clears up a lot garbage files that build up.
It also allows you to manually install apps you want back.
这个答案有帮助吗?
Problem is i have not created a backup.
I did mention use iTunes to create a backup. in the 3rd bullet point.
It worked omg thanks!
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 56
2条评论
Can you clear up enough memory to fully download the app and then delete it?
由 Jack 完成的
I tried that but it doesnt seem to continue downloading.
由 Cody Rutherford 完成的
