跳转到主内容
加入维修社区 - 创建账户
The Western Digital My Passport Ultra is a USB 3.0 portable storage device with capacities from 500 GB up to 5 TB.
Why doesn't WD My Passport Ultra 2TB allow me to paste files.
I was intending to use WD My Passport Ultra 2TB as an Archive to backup all my files and folders. Unfortunately, it is not allowing anything to be copied or saved on it.
Please instruct how to change this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
What model Passport are you using and are you using it for Mac or Windows?
完成的
My 2 TB WD Passport Model no- P/N WDBYFT0020BRD - 0A, i am using it in my windows 10
please help to resolve this...
完成的
添加一条评论
2个答案
已选择的解决方案
Hi katerine albarellos, first of all, what computer operating system are you using?
as S W mentioned, if it used for mac, you need to use disk utility to format it to either exfat or macos extended (journaled). If there is any current files in your external hdd, be sure to backup or make a copy , as re configuring the hdd partition, will result in data loss.
to be able to use for windows, what i had done is to use disk utility to spit into two partition, one is using macos extended (journaled) for time machine, misc and another exfat, which windows can write to it
http://www.mactip.net/guide-how-to-forma...
这个答案有帮助吗?
得分 4
1条评论:
Format not an Option , Do you have any other solution...
完成的
添加一条评论
WD Universal Firmware Updater for Windows
may be this gone work for you….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
katerine albarellos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 15,879
