跳转到主内容
The M15x is Alienware's 15 inch extreme gaming laptop.
7 个问题 查看全部
power adapter flashes when plugged in to laptop, unit wont power up
Alienware 15r2,
AC adapter light flashes once plugged in to laptop. It then has to be removed from power to reset it. Kinda like it senses a short when plugged in and goes into a safe mode.
I have replaced DC input assembly inside the laptop. Checked all connections to the best of my limited ability. Looking through forums , the next step seems to be replacing the mainboard. Just wondering if there is a test to determine if this is really required.
Thanks for any info
Cheers
Phil
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Does it boot to the bios or post?
完成的
And does using another power adapter yield any results?
完成的
i tried a different power adapter, same result. It doesnt boot up at all, all that happens is the power adapter light flashes...
完成的
添加一条评论
1个答案
The motherboard has a problem. If the power adapter shuts off when you plug it into the laptop, and you have to unplug the power adapter from the AC socket to reset it, the problem is in the motherboard. The power manager is defective. The rest of the motherboard is probably good if you do not hear any beep codes on startup.
You can call Dell tech support if the laptop is still in warranty and they will send someone out to repair it, if not in warranty then they can diagnose the problem and give you the cost to repair. Good luck.
这个答案有帮助吗?
得分 0
1条评论:
So if the motherboard has a problem, I guess i'm replacing it...
Unless someone else has a better option..
cheers mate
完成的
添加一条评论
添加你的答案
Phil Surtees 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 1,764
