跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
L3204_RF missing from board and constant searching
This iPhone 6 was water damaged. I removed all the EMI shields and cleaned up the board. The phone does turn on and everything works but the cellular network.
Modem firmware does not show up in Settings>About and *#06# doesn't return the IMEI.
There is a missing part near the baseband chip and I thought it might be the cause. What do you guys think? Can I short the part and see if it works?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
This is an inductor, not a filter (ferrite bead).
L3204_RF is used within the switching power supply (U_PMICRF). If it is missing, that would impede the production of VREG_SMPS2_1V25 and that explains why (or partly why) the baseband functionality isn't working.
You cannot short it out otherwise the voltage rail will not be produced. Inductors are integral in the design of SMPS. You can read more here: https://en.wikipedia.org/wiki/Buck_conve...
这个答案有帮助吗?
得分 3
3条评论:
@refectio excellent answer as always
完成的
@refectio Thanks for the answer. I had the missing part replaced and the modem firmware showed up in settings and searching is gone. But it can't find service now.
I suppose I should be looking elsewhere now as this is a water damage.
Any suggestions would be appreciated
完成的
Does the rest of the phone (the "computer" part) work ok? If so, then focus your attention on the baseband IC. It is very sensitive, just like the Touch IC's on the 6 Plus. It also suffers from poor quality traces and pads. Some experienced micro-solderers have given up trying to find a long term fix, others have had success with "long jumpers". Check out this Q&A (No Service issue on iPhone 6).
完成的
添加一条评论
添加你的答案
shoeib 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 318
