跳转到主内容
Guides and support for various television (TV) brands and styles.
20 个问题 查看全部
Why is my screen very bright
Suddenly the pictures screen of my Samsung UN55JS7000 55-inch 4K SUHD TV are very bright
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@satishk does it still display a normal screen or just a very bright screen? Does it display normal images?
完成的
添加一条评论
1个答案
最有帮助的答案
Have you tried fiddling with the settings on your TV? You should be able to adjust screen brightness by clicking the 'Menu' button on your TV or remote and selecting the setting called 'Brightness'. You can also adjust the color in this same menu.
这个答案有帮助吗?
得分 1
2条评论:
Yes, I have tried all the settings nothing worked. Also talked to Samsung support people and went through various adjustments. Nothing helped.
完成的
Is the increased brightness associated with any other event? Or does it seem to have started randomly?
完成的
添加一条评论
添加你的答案
Satish Khera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 102
