跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1053 个问题 查看全部
Can an SE be moved into a 5s housing?
I'm wondering if i can transfer all of my SE components into a custom 5s housing. I've looked around quite for other people that have asked the question, and it usually no since the iPhone SE logic board is supposedly slightly bigger.
However i've seen cases where people say theyve put an iPhone SE into a 5s housing shell anyway. Furthermore online there are 5s/SE custom housings, even though they aren't interchangeable?
I've looked at a lot of pictures online of the housings and i cant find any real differences. I might just dismantle my personal 5s and SE to see for myself.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
1个答案
最有帮助的答案
No, the internal size and screw holes are different.
这个答案有帮助吗?
得分 4
8条评论:
how do people supposedly do it anyway?
完成的
I've no idea. The camera and flash are different between the two models.
完成的
i just did it anyway. Flash wasnt really any different and camera fit anyway
完成的
Awesome! You should add a guide here on how to do it.
完成的
How do i do that? There wasn't really any difference except i kinda had to squash the nfc anetnna above the camera since there wasnt a slot for it. Other than that it was exactly like a 5s. The motherboard is technically slightly bigger, but the screw holes are the same.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Bob Mcroy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 5,374
