跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
CPU i5 3,1GHZ Throttled to 1.6GHZ
So i tried to replace my i5 2400 3,1 GHZ CPU with a i7 3770 it did not work. I reinstalled the i5 2400 and everything worked normal except the Fans for ODD and CPU. Well i thought no problem i will regulate it with software. But then i experienced a big drop of perfomance in OBS and Logic. I installed intel Power Gadget and noticed the CPU Frequency is locked to 1.6GHZ.
The Apple Hardware-Test says: 4SNS/1/C0000008: TLOp--124
I searched in the Web and found that it must be a Temperature Sensor connected to the LCD.
1. SMC PRAM VRAM Reset
2. I ordered a new LCD Tempsensor - replaced it but nothing changed.
3. I ordered a new V-SYNC /TempSens Cable (connected to the LED Backlightboard) nothing changed.
4. I ordered a new LCD Data Cable - nothing changed.
5. I ordered a new Logic Board + CPU - nothing changed.
So these are the steps I did until now and I don't know what to do now...
The only thing left i could imagine would be the LED-Backlightboard maybe reinstall OS or could be something wrong with the EFI, Powermangament I dont know.. Maybe someone experienced the same issue or knows how to repair it.
Everything else except Fans going wild and CPU is throttled works well.
EDIT: (This Programm is called HW-Monitor and is the only one that shows me 128° on LCD)
EDIT:
So i was away for like 2 hours and the imac was in Sleepmode when i came back i saw this:
Sadly it went back to 1.6GHZ after a short period of time.
EDIT:
So its definely reproducable. I have to put the iMac in Sleepmode for 20-30secs and when i wake it up the CPU runs normal ant turns to 1.6GHZ after 10secs. What the !&&*...
Maybe another hint. When I turn on Sleepmode the fans are stopping. NOW when i wake up the MAC TGPro is showing my some N/A Temperatures:
GPU DIODE
Platform Controller Hub DIe
As soon as these both Temperatures are availabe the Fans power up and the CPU gets throttled.
EDIT:
Tried to reinstall OS X did not help..
EDIT:
Tried to run the iMac without the LCD on a second Monitor did not work.
When i opened the iMac i noticed strange "glue" on the poweradapter:
Also i run a SystemDiagnosis which gave me the same error as the AHT:
This week i will probably bring it to an Authorized Apple Reseller and hope the can help me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
Did you change the hard drive while you were at it?
完成的
No i ordered it with an SSD and HDD, i had to change the SSD like 3 years ago but everything worked fine. HDD is still the same.
完成的
Well but of course i had to disconnect the HDD and SDD to change the CPU / Logicboard
完成的
Could it be a faulty connector on the LED-Backlightboard ?
完成的
Tell me about the new SSD you installed.
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
I was able to fix the problem. Switched the LED-Backlightboard and it worked.. I think the connector to the LCD V-Sync/temp - cable was faulty. Thanks for everyone considering solutions!
这个答案有帮助吗?
得分 1
3条评论:
So everyone with the TLOp Error should consider to check the V-Sync / Temp cable and the LED-Backlightboard! :)
完成的
I have the same TLOp Error.
My Current LCD panel is DJ4K (EEE code)
(The EEE code can be found on the back of the panel in the Serial Number.)
ex. CP4116384MKDJ4KCL
My Current Backlight Board is HGH (EEE code)
(The EEE code can be found on the Serial Number label.)
ex. * 4G 203 04VS HQH B *
Which Backlight Board did you use? HQH or HQG?
(to identify the EEE code, please look at the serial number of the part itself, not of the machines serial number. it will be as follows XXXXXXXXEEEX)
I notice there are a couple of different Manufacturers of this Backlight Board also.
My Current one is made by Sumida
完成的
BTW, I want to compliment you on yourr excellent feedback in Diagnosing this issue.
完成的
添加一条评论
Can't say for variance, but it sounds like some temp sensor for the CPU is going crazy. The high fan speed and throttling could be because of thermal reasons (or so it thinks). Try reseating the CPU and see if that helps. Also, tell your temps please.
EDIT: did you replace the thermal paste?
这个答案有帮助吗?
得分 0
2条评论:
Just watch the pictures everything is there ;) .
The thing is I switched the Logic Board + CPU. So the problem can't be the Logic Board or CPU.
完成的
I replaced the thermal paste when i switched to the i7 3770 and again when i switched to the i5 2400. But thats the old logicboard. The new Logic Board came with the CPU attached.
完成的
添加一条评论
I’m having the same problem with clock speed (blocked at 1,6Ghz) and fans at full speed BUT Apple Hardware-Test is not giving me any error or failure.
I’ve passed AHT a lot of times with no errors detected, every sensor is giving corrects values,… i don’t know from where is coming the issue, but the symptoms are the same. Something is happening with SMC that Apple Hardware-Test is not seeing.
The computer is an 2011 iMac i7 at 3,4Ghz.
这个答案有帮助吗?
得分 0
1条评论:
Hey you also should check the connections on the LCD-Monitor. There are 2 !
One is the Cable for the Video Signal and the second on the top right is for temperatures and other stuff. It is bellow the black tape. Check these Connections !
完成的
添加一条评论
添加你的答案
Valentino Vian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,005
