跳转到主内容
加入维修社区 - 创建账户
Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
Why does my machine stop mid-cycle?
I can hold onto the knob or jam something behind it and it will continue but it has progressively gotten worse. It stops about the same place everytime, toward end of wash going into rinse and now sometimes during rinse. From what I've already read and the fact that this is the only malfunction, I think it may be the timer. Is that right and can I, a handy layman, fix it myself?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Please give us your model number so I can find your part.
完成的
添加一条评论
1个答案
It sounds like a plumbing problem rather than a machine fault.
Turn the machine off.
Turn the cold &/or hot water supply taps off
Disconnect hot & cold water supply hoses connected to the back of the machine
Put the NOW open ends of the hoses into a bucket and turn each one on slowly
This is checking that both are supplying water to the machine as required
If either hose does not run then it is blocked or the supply to it is turned off elsewhere
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly Jackson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 504
