跳转到主内容
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Stuck in reboot loop?
Hi –
I have a 7 inch Samsung Galaxy Tab 3 that recently developed what I think might be a boot loop. It turns on normally, operates for a minute or so and then restarts.
I have tried factory resetting it, but it does not reset – everything is the same after it goes through the reset process.
I then tried reinstalling the operating system – downloaded Odin, downloaded T210RUEU0CNI1, downloaded Samsung drivers -- tried the newest one, one that came out when the tablet was made and one that my computer downloaded from Windows Update.
Went through the operating system install process using Odin 3.07. There was a progress bar on Odin, but none on the tablet. I watched a couple of videos on reinstalling the operating system and they showed a progress bar on the tablet, so I’m guessing that while Odin and the driver and the operating system went through the process, the tablet did not.
The tablet was unchanged – all of the apps still there, and the turning off and on problem still there after many attempts to reinstall the operating system.
What do I do now? I’d like to get this tablet working again. Could this be a hardware problem? Thanks for any guidance.
-- SWM
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What happens if you remove the battery and plug it back in - We have a guide on how to get there here: Samsung Galaxy Tab 3 7.0 Battery Replacement
完成的
添加一条评论
1个答案
I tried that many times as well. Same result -- no change, the reboot problem persists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Matthews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,159
