跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2013 年末机型 / 2.7 GHz 或 2.9 GHz Core i5 处理器,或 3.1 GHz Core i7 处理器
No power on, no trickle voltage on logic board, blown Mosfet
Hi all.
We have a suspected power surge on a late model iMac.
Logic board ID 820-3588 , power supply tested OK and swapped in known working power supply.
Symptoms;
1. No Trickle diag LED at all
2. No power on , chime etc
Blown Q7610 dual N channel mosfet which is a FDMS3602s FET
http://www.mouser.com/ds/2/149/FDMS3602S...
No other liquid or burn marks on board itself.
Mosfet appears to have shorted or had voltage applied beyond its limits.
Fet failed dramatically after a few power on attempts and was not blown initially on inspection.
Have replaced part with exact match , no power on yet fet is intact thus far.
Anyone else seen anything like this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
I had to extrapolate from your part number which machine you had. Please let me know if the icon is your machine.
The first thing to do on this one is to replace the power supply:
iMac Intel 21.5" EMC 2638 电源更换
这个答案有帮助吗?
得分 2
10条评论:
Hi Mayer , yes indeed that is the iMac in question. Swapping the power supply has already been done and did not solve the issue sorry to say. All voltages into the logic board were correct with the original power supply also but swapped a new one in just in case.
由完成的 分享
Let get this straight, you replaced the power supply but get NO diagnostic LEDs?
由完成的 分享
This got confusing because you used two questions on the same problem but provided different information in the two. Then when it was caught (the duplicate question) they were combined. My answer was to the question that was deleted. It did not contain the information this question did on the power supplies. So PLEASE just ask the question once and if you need to add updates to the original question.
由完成的 分享
Not sure what you mean. I have posted two different issues on two different iMacs at different times. This one relates to an iMac that does not power on , no LED at all despite replacing the power supply. The thread above is quite strait forward.
To make it clearer.
iMac tested - No power on.
Screen removed - No LED lights at all.
Power supply swapped with known working one - No LED
Power on test - Blew mosfet as described above
Removed logic board - Replaced mosfet
Retested - No LED same original condition however the replaced mosfet is staying intact for now.
由完成的 分享
My iMac 2638 has the same issue. I bought a known good power supply, installed it, and the situation remained the same (no power, no boot, no fans, no diagnostic-LEDs at all...). Any ideas on a next step for this?
由完成的 分享
显示更多的5条评论
添加一条评论
添加你的答案
markduff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 1,283
