跳转到主内容
Code says Int and won't stop the rinse cycle
The error message that is being displayed is "Int." It continues to cycle the rinse cycle. When I tried holding the power button it just starts the rinsing cycle again. Please help! Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@kaykay10 "The "int" means interrupt. The "int" will display when the user presses "Stop" trying to interrupt the "Clean Cycle" and the "INT" will not go away when pressing start and will not resume the cycle.
If necessary the cleaning cycle may be interrupted by pressing the STOP button. However, this will not immediately stop the cycle. The machine will display "int" (interrupt) and continue with several rinses and drain steps to ensure that all remaining bleach is rinsed from the washer. When the Clean washer cycle is paused "INT" the control board's software stores position of the cycle; even if the power is disconnected from the unit the control still saves the position of the cycle.
Disconnecting the power supply from the machine will not clear the "INT". It will take the unit 3-5 seconds to resume the cycle once the start keys is pressed to resume the cycle. If the unit does not resume within 3-5 seconds check the connections between the user interface and the main control board." from here
这个答案有帮助吗?
得分 1
2条评论:
How do I get my kenmore series 600 to drain? It won't finish spinning and draining the las couple inches of water
完成的
Hi Oldturkey03,
I am having the same "Int" problem and was trying to read your response as to how to fixt it yet when I click "here" nothing comes out. Please help!
完成的
添加一条评论
添加你的答案
Kay Knapp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 8,900
